How to controll Sys_Fan on a gigabyte b75 motherboard
Billy_1
60
Hello!!
Does anyone know how to control the fan speed of my Sys_Fan on my gigabyte b75m-d3h motherboard? It currently spins at quite high rpm and it is not needed to do so.
Any answer is acceptable thank you all for your time!!
You can do that in BIOS. Here is a photo I've found on YouTube to help you find the right tab in BIOS. That's about all I can tell you because I don't have the above mentioned MB.
Hey thx for replying!
I found that too tbh. But it only offers static rpms. I just found out that i can use easytune6 to do that more "smart". Anyway i finally got around to it!!
Thx for your reply, i am gonna pick your answer as solution because other people may find it helpful!
