Evernote is a digital workspace which allows you to organize and save your notes, files, and documents together. It also has features which allow you to sync with other social media platforms to make it easy for you to promote your content. Here is how you can create a note in Evernote.
1. Download the app first from the Play Store or App Store. You can also use the desktop version by logging on to their website and create an account to use it.
2. After downloading and installing the app, launch it by tapping the icon on your phone. Create an account or log in using your existing credentials.
3. On the main page, tap the elephant on the upper left corner of the page to go to the Menu. There is also a shortcut to make a new note found on the lower left corner.
4. On the menu page, tap the note icon with a plus sign to create a new note. Write a title and description for your note. You can add the time by tapping the clock icon on the top screen.
5. After you finish writing, tap the check icon on the upper left side corner of the screen to save your work. You can also tap the three dots on the upper right corner and then Save. You can edit notes whenever you like.
![gKmhUZV.png](/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FgKmhUZV.png&hash=e04fd25d9ba7e51caf037811cd420634)
![SPYAHo1.png](/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FSPYAHo1.png&hash=e1f96234a88fd5c7307b97f92b818a22)
![xmw0L46.png](/proxy.php?image=http%3A%2F%2Fi.imgur.com%2Fxmw0L46.png&hash=562b9a61991fa02360d34698705812a7)
![d5ewuUc.png](/proxy.php?image=http%3A%2F%2Fi.imgur.com%2Fd5ewuUc.png&hash=1082940496c94d5488a8f8006163e66a)
