how to create Lan using 16 port switch
Debashish Dhara
21
I have a Tp-Link Tl-wr841n 300mbps router and a Dlink DES-1016D 16 port splitter and i using 2Mbps internet connection. the main pc is using a LAN connection through the Tp-link router , the main connection is coming via cable Net. I work in a private office , there are 25 pc , actually I want the LAN sharing to 10 PC .Please help and Oh! I did tried to make CAT5 network cable but some how its not working properly ,can u attach a proper Pic of CAT5 diagram so it might help. I stay in India ,Kolkata. Thanks.
use an image hosting site.
router to switch with cat5, switch to PC with cat5, switch plugged in turned on, do lights light up? Does this work
Add another machine to switch with cat5, does that light light up.
Bascially it would go modem to router, to switch. You can attach the computers to any available port. But it doesn't look like you'll have enough ports to hook up every PC in the office.
As for Cat5, most people use standard B for patch cables. white/orange, orange, white/green, blue, white/blue, green, white/brown and brown. (going from left to right. You then slide the head over cables with the clip facing away from you. Both ends of the cable should be the same. A crossover cable has one end where the green and orange pairs trade places. (not relevant in your case.)
https://www.trangosys.com/cat-5-ethernet-cable-standards-pin-out-assignments
I want to know more about Tp-Link Tl-wr841n 300mbps router .....i have a Dlink DES-1016d what is this call does it will work with my router and does it will handle 10 PC continuously , it has 16 port... Thanks .
Oh this is a very basic question and takes long time to explain, there is already a write up for this, click HERE.
After a decade of experience, I tell you to buy pre-made CAT5. They look easy to make but it's not.
The same problem, i took some picture but how can i send u only showing url option. if i am doing from the router its fine but when i just unplugged the wire and put on the 16 port spliter its showing unidentify network. Do i have to put IP on the TCP/IPv4 .For the time doing in two PC, just checking.
