[SOLVED] How to create or design PCB or Motherboards for Nono - ITX Systems
Ragahv
198
I want to make my own motherboard or design PCB at home using 3d printer or 2d printer and put the following on it such as:
DDR4 RAM Socket
Mobile CPU / GPU
PCIE-Mini Extension for Mobile GPU Expansion on the Nano - ITX motherboards
Embedded Sound and WIFI, 4G, Blutooth Module
I don't know which software to use. There may be a printing software for pcb but i don't know of one. I know on youtube there are many ways of designing a pcb layout. I am good in electronics. I just want to make a pcb board and attach or solder a mobile cpu onto it and start from there. My aim is to make a mini motherboard or a nano motherboard myself.
You do realize that current motherboards are more than just a plastic sheet with holes in it, right?
Multiple layers, with traces between each.
AutoDesk:
https://www.autodesk.com/solutions/pcb-design-software
Basic:
google for 'design PCB' and you'll get loads of options.
However, this is a non-trivial exercise.
AutoDesk:
Basic:
