I want a build that will last 5+ years, with reliable parts. I don't intend to do much upgrading, except perhaps the GPU and a RAM upgrade should the need arise and I can squeeze out a few more years.
Needs:
*Well cooled, with ability to overclock without any hassle.
*Reliable brands. I have good experience with MSI and Corsair in the past, but I am all ears for new suggestions.
*I rather want to go with the i7 unless there is a compelling reason not to.
*I want this thing to run silent, yet be well ventilated.
*I have absolutely no need for "bling". No need for LEDs etc.
*A functional, well ventilated case that has enough room for several fans to create a decent airflow, but once again, I have no need for "bling". Naturally it also needs to have enough space to fit the cooler should it be large in size.
I will be transferring my MSI GTX 970, SSD and HD from my old build, along with several Noctua fans.
I am situated in Norway, and will be buying from local online stores here. Here is a current list of components I have picked out, and I am primarily looking into cost saving measures. Any potential compatibility issues?
Are some of these parts overkill? Can I buy a cheaper MB and still overclock in the future without a problem? Can I get away with cheaper RAM? Should I go with 1x16 GB or 2x8 GB? Do I need that much power? Can I swap out the cooler for something cheaper? Water cooling perhaps?
http://uk.pcpartpicker.com/list/nC838K
Intel Core i7-6700K 4.0GHz Quad-Core Processor
Noctua NH-D15 82.5 CFM CPU Cooler
MSI Z170A GAMING M3 ATX LGA1151 Motherboard
Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory
Corsair 200R ATX Mid Tower Case
Corsair RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Needs:
