How to demote a BDC from being a domain controller
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.windowsnt.domain (More info?)
I have a BDC that has a corrupted user database. The PDC
(Windows 2000) seems to be fine. Howvwer the PDC does no
longer recognize the BDC as a BDC. So the Netlogon
Service on the BDC cannot start.
I tried to join the BDC to a secondary domain I have, what
does not work.
I also tried to get the BDC in it's own domain, what does
not work either.
Is there a way (like in WIndows 2000) to DEMOTE the BDC to
a plain standalone server?
Thanks.
You cannot demote NT4 DC's, this is new with Win2k. A reinstall is required
to change the role of NT4 Servers. You try to reset the secure channel with
Netdom or Nltest.
Scott Harding
MCSE, MCSA, A+, Network+
Microsoft MVP - Windows NT Server
"Gerry Lieberwirth" <gerry@lieberwirth-consulting.com> wrote in message
news:13a4001c44409$6e243e80$a501280a@phx.gbl...
> does not work.
> not work either.
> Thanks.
Is there a way to repair the connection between my BDC and
PDC?
If I re-install, wouldn't it be better to go immediately
to Win 2000, or can I upgrade and then demote?
You see, the BDC also houses the Backup software of our
servers, a reinstall would require to fully reinstall also
the backup software.
Gerry
>-----Original Message-----
secure channel with
>Netdom or Nltest.
>Scott Harding
wrote in message
PDC
no
what
>> does not work.
does
>> not work either.
to
>> Thanks.
You can use Netdom or Nltest to try and repair the PDC/BDC connection.
Scott Harding
news:1383001c44419$86aef2a0$a301280a@phx.gbl...
> PDC?
> Gerry
> secure channel with
> >Netdom or Nltest.
> >Scott Harding
> wrote in message
> PDC
> no
> what
> >> does not work.
> does
> >> not work either.
> to
> >> Thanks.
I used NLTEST to identify the problem, using NLTEST
the /DCNAME: gives me a wrong PDC.
I could not find the NETDOM command? where can I find
that? I did install the NT Resourse Kit (SP4).
Gerry
PDC/BDC connection.
>Scott Harding
wrote in message
and
>> PDC?
also
>> Gerry
>> secure channel with
>> >Netdom or Nltest.
>> >Scott Harding
>> wrote in message
>> PDC
does
>> no
>> what
>> >> does not work.
>> does
>> >> not work either.
BDC
>> to
>> >> Thanks.
Use getsids.exe to compare the administrator account of the
BDC and the W2k PDC emulator they should match exactly
because the DCs share a common SID.
news:142c801c444c1$73721610$a601280a@phx.gbl...
I checked the SID's and the administrator SID's are
correct. But here is my problem....
NLTEST /DCNAME:MCGRAWGROUP gives me server name
\\WILLOWNET wich is NOT a DC at all.
NLTEST /DCLIST:MCGRAWGROUP gives me server names
\\WILLOWNT-REC (PDC)
\\MCGRAW-BDC
What is should be. Now on \\WILLOWNT-REC, there is NO
computer/domain account for \\MCGRAW-BDC.
If I open the Server Management Utility on MCGRAW-BDC for
MCGRAWGROUP, it says "Network has been deleted", if I open
it with "MCGRAW-BDC", is shows "Workstation" instead
of "Server" or "Backup Domain Controller".
I don't seem to have the NETDOM program either. So how
can I re-join MCGRAW-BDC with the MCGRAWGROUP?
Do I have to re-install, if so, should I install Wind 2000
Server instead?
Thanks,
Gerry
the
wrote in message
Download Netdom 1.8 from the following site:
ftp://ftp.microsoft.com/reskit/nt4/x86/
This is the NT version. Run the following command
on the BDC with domain admin rights:
NETDOM BDC mybdc /RESET
If it fails what is the exact error. Also you may
want to enable auditing for security policy changes
then synchronize the entire domain. Next check
the system log of the event viewer on all DCs to
see why the synch failed.
> \\MCGRAW-BDC
> Server instead?
This is the result of the NETDOM BDC \\MCGRAW-BDC /RESET
command:
NetDom 1.8 @1997-98. Written by Christophe Robert -
Microsoft.
Querying domain information on computer \\MCGRAW-BDC ...
The computer \\MCGRAW-BDC is a domain controller of
MCGRAWGROUP.
Searching PDC for domain MCGRAWGROUP ...
Found PDC \\WILLOWNET
Connecting to \\WILLOWNET ...
Verifying secure channel on \\MCGRAW-BDC ...
Secure channel failed. The SAM database on the Windows NT
Server does not have a
computer
account for this workstation trust relationship.
The BDC secure channel with the PDC is probably out of
sync.
Resetting secure channel ...
Changing computer account on PDC \\WILLOWNET ...
The network request is not supported.
As you see, it is looking for WILLOWNET instead of
WILLOWNT-REC..........
wrote in message
>> \\MCGRAW-BDC
for
open
2000
>> Server instead?
I bet there is a static entry in the lmhosts file on the BDC.
Check the c:\winnt\system32\drivers\etc.
news:148c801c444e8$9112db10$a501280a@phx.gbl...
> command:
> Microsoft.
> MCGRAWGROUP.
> computer
> sync.
> wrote in message
> >> \\MCGRAW-BDC
> for
> open
> 2000
> >> Server instead?
