How to Disable LED Trace lighting on a motherboard
gotcha357
So I have a bit of an issue here. The board I decided on, (being the Z97M GAMING from MSI) has LED trace lighting around the Audio portion of the board. The problem with this is that the LED is red and doesn't match the rest of my build. So I need to know if there is a way to disable the LEDs.
Hi,
According to MSI's website, the LED path is to isolate the audio section of the motherboard from the rest so there isn't as much interference.
Sorry, but it doesn't look like you'll be turning it off.
