My Brother printer display is showing replace cartridge for LC51. It has not been used that much. Is there any way the sensor can be disabled or bypassed so that the remaining ink in the carrtidge can be used up?
Hi there,
Rather than run out for a new toner cartridge use a small (.5 x .5 in.) piece of black electrical tape to cover the sensor hole on the non-gear side of the cartridge. By covering the hole the printer is fooled into thinking the hopper is full of toner.
Cartridgeworld have been around a while. They offer printer supplies for all of the printer manufacturers If you visit their website you’ll find a lot of products of your need. I have found useful tips covering everything from refilling tips to getting ink stains off your fingers. I strongly recommend this to all of you. The website is www.Cartridgeworld.us
