How to disable "WARNING! PWR_FAN 0 RPM" notifications?
Gondvanaz
143
My motherboard is ASUS M5A97 PRO. I plugged my rear fan into CHA. FAN 2 socket instead of PWR_FAN socket because it allows better cable management and now i am regularly getting "WARNING! PWR_FAN 0 RPM" notifications, everytime when i start the Windows. It is really annoying, how can i disable these notifications?
Isn't CHA FAN 2 correct port? It is 3-pin port too, does it matter whether it is CHA. FAN 2 or PWR_FAN?
If the system thinks there is supposed to be plugged into PWR_FAN, then you should probably do that.
