G georgesun238 Commendable Jul 1, 2018 13 0 1,510 Jul 1, 2018 #1 I wanted to get a i5-8400 for a build and I know that turbo boost on the CPU can allow it to run at around 4.7ghz. How do I turbo boost it so that it runs that high?
Solution richiestang_78 Jul 1, 2018 The 8400 turbos to 4.0 GHZ not 4.7 https://ark.intel.com/products/126687/Intel-Core-i5-8400-Processor-9M-Cache-up-to-4_00-GHz And turbo is done automatically by the chip when required, otherwise it will run at lower speeds to conserve power and heat.
richiestang_78 Glorious Mar 3, 2015 5,965 687 46,890 Jul 1, 2018 Solution #2 The 8400 turbos to 4.0 GHZ not 4.7 https://ark.intel.com/products/126687/Intel-Core-i5-8400-Processor-9M-Cache-up-to-4_00-GHz And turbo is done automatically by the chip when required, otherwise it will run at lower speeds to conserve power and heat. Upvote 0 Downvote Solution
G georgesun238 Commendable Jul 1, 2018 13 0 1,510 Jul 1, 2018 #3 richiestang_78 : The 8400 turbos to 4.0 GHZ not 4.7 https://ark.intel.com/products/126687/Intel-Core-i5-8400-Processor-9M-Cache-up-to-4_00-GHz And turbo is done automatically by the chip when required, otherwise it will run at lower speeds to conserve power and heat. So, please correct me if I'm wrong but what I'm getting from that is that, the chip will automatically run at up to 4ghz if needed? Upvote 0 Downvote
