Hi
At long last I have had Fibre Broadband installed and ethernet-wise speeds are phenominal compared to the paltry 55Mbps I was getting with Sky.
However in a quite large house, coverage is not all it could be. I have split the 2.4 and 5gHz bands as I have some devices that will only work on a dedicated 2.4 band. So depending on the room, we have been selecting the appropriate band for normal WiFi re mobile Phones and Tablets - rooms very close to the Router 5gHz band and ones further away the 2.4 band. There are a few rooms though which struggle to connect at all - these are rooms furthest away from the Router. The router cannot be moved and with Sky, I deployed 2 Boosters - one downstairs in the Hall-way and another upstairs on the Landing.
My new Virgin Router is the 5x model but trying to get hold of boosters from Virgin has been a nightmare and for me impossible! So I'm asking for help as to what would be the best extenders/boosters I should acquire externally so that they can maintain the dual-band capability and will work with my Router.
I've looked at several TP-Link ones but before splashing out the dosh, maybe I could ask for a recommendation or 2 please with specific model no.s?
Many thanks indeed
Many thanks indeed
