how to factory reset lenovo edge 15
-Open up "PC Settings" (you can find it in the Apps screen or do a search)
-Click update and recovery.
-Then recovery
-Then choose from the 3 options you are given.
I suggest that you first try a Refresh (The first one) but if you really need or want you can "Remove everything and reinstall Windows"
-Then recovery
