[SOLVED] How to figure out Ram Speed.
holmesc
64
extreme_noob
Respectable
It's right in the name. 3200Mhz. Sometimes BIOS will list it as 1600Mhz since that's the true frequency the ram is actually running at (but double data rate makes it 3200 Megatransfers/second, which is often falsely called megahertz). If you mean making sure that your ram is running at that speed, you just have to go to the settings with XMP profile and set it on.
extreme_noob
Respectable
holmesc
64
Thanks guys. By the way, found out my ram frequency was set on automatic. Is this better then setting to it's (3200) max frequency?
