childoflight :
How to finally delete PC Cleaner Pro. Nothing so far has worked. It isn't in my programs. My Security says it is turned off. I can't find it anywhere. My anti virus will not install untill I remove it. - ???
I was downloading files from Adobe's site when suddenly the download was interrupted by warning from PC Cleaner that I had attracted a virus that had corrupted my Adobe files and would affect whole computer eventually. Download PC Cleaner Pro to fix. I'm sure you all know the problem, but the point is that they basically saisd you had a buy their product to be free of the worm. I've tried uninstalling from Windows 7 64 bitto no avail. Even tried going back to previous restore point - computer froze up. While it appears to be gone, I have noticed JPEG files are disappearing from their folders on both internal and external drives. In short PC CLEANER PRO IS a BAD VIRUS / WORM. I'm surprised that Adobe had it on their site in first place - the blab said that my Adobe downloads were at risk, specifying I was downloading from Adobe. Have not yet successfully removed it. Will keep persevering.
Cheers
Garry
