How to fit a dual slot GPU into a single slot case!
You could buy a ribbon cable adapter to mount the card somewhere else (or the wifi adapter for that matter if it's taking up a PCIe slot you need, either way you can get an adapter/ribbon cable extender for a device.. :)
