[SOLVED] How to fix 0xc000001 and WDF_Violation ?
Mar 16, 2021
19
Idk what to tell here but if u need any information I'll answer.
I force turned off my computer the other day and this morning i woke up, turned on my PC and this happened:
  1. At first it shows "Recovery 0xc0000001"
  2. I press enter and then a WDF_Violation comes up ?
why you do that? it can mess with windows if its shutdown unexpectedly... as you can tell
do you have an installer USB?
if not, On another PC, download the Windows 10 media creation tool and use it to make a win 10 installer on USB
boot from installer
on screen after languages, choose repair this pc, not install.
choose troubleshoot
choose advanced
choose start up repair - this will scan PC and maybe fix this - will ask for logon info
(its a long time since i suggested startup repair)
wdf = Windows Driver framework. Possibly a driver error.
boot from installer
choose troubleshoot
choose advanced
