Question How to fix 515 power supply fan not detected
4
hey,
I have an HP 8000 Elite which I recently changed it's power supply.
The computer is working great, but when I turn on the computer, I get a 515 power supply fan not detected error.
I can press F1 to continue anyway, but it's really annoying.
I did some research but all the diagrams are a bit different from what I have.
I found this schema:
View: https://imgur.com/58qTH6B
And I was wondering if I should do the same wiring ?
Which wire should I connect to which?
Thanks!
did you used a normal psu or a exact replacement part for that hp?
if you used the exact part shouldn't make this weird report, if you used a different part, well, all you can do is read, cut solder, buy adaptors and similar stuff to make it work the way you need it
that or sell the thing, a prebuilt pc is always just problems
hey,
I had to get an adapter because the motherboard had a 6 pin connector:
https://www.ebay.com/itm/323857034491
hey,
Thanks!
I have hp8200 elite town also.then i get the answer as below
https://linustechtips.com/main/topi...sff-fix/page/5/?tab=comments#comment-13194112
