how to fix a 0xa00f4244(0xc00d36d5)
Jacqueline_51
We can't find your camera. Check to be sure it's connected and installed properly, that it isn't being blocked by antivirus software,and that your camera rivers are up-to-date. If you need it , here's the error code: 0xA00F4244(0xC00D36D5). How do I fix this problem.
BRUH i had that problem for ages and the technician couldn't solve it but i somehow managed to in 2 minutes??? what;s worse was that the camera is literally installed in the laptop there's no reason why it cant detect it that's dumb. anywway, go to device manager> imaging devices> [your camera name, e.g., HD Webcam]> driver> update driver> search automatically for updated driver software AND THEN IT'S DONE. i hope this helps good day to all of u :^)
Do you have the laptop?
May try this: Windows can't find or start the camera https://support.microsoft.com/en-us/help/13753/windows-10-can-not-find-or-start-the-camera
