Question How to fix a RX 460 fan?
meistr0
15
Hey,
Recently i quit pc gaming and sold my gtx 1650 super.
I installed my rx 460 into my system to use the pc as a office pc since i have a i5 9400F.
However one of the fans is very noisy, because it is loose. The screws are tight. The mechanic is broken i guess.
Is there any way how i can turn off that one fan, because i don't intend to play on that thing anyways.
Thanks in advance.
Lutfij
Can you parse a link to the card you're working with? If you're only using the GPU for display output and never going to use it for gaming, you might want to see if you can invest on a passive cooler for the GPU, something like Arctic or Raijintek make. You could also look at a replacement fan kit for the card off of Aliexpress.
