i open amd over drive and it opens the warning screen and then it says
"Amd Overdrive Failed To Start"
I have seen this happen if your hardware is throwing some errors and is unable to report to the OS what the system specifications are. Are you already overclocking in the BIOS?
Reset BIOS settings to default and try again. Re-install the application.
You shouldn't be overclocking in the software anyways.. but you want to make sure that your system is stable. Software overclocking is silly.
