Question How to fix atikmpag.sys crash with Ryzen 2400G
Jul 27, 2019
I built a PC with a Ryzen 2400G and it has been crashing a lot. When it does, I get a message saying that atikmpag.sys is the reason for the crash. I have an Asrock B450m Pro4 motherboard and I was supposed to update its driver package before updating the bios. I did not do that, and I believe this to be the cause of my crashing issue. I have also read that they Ryzen 2400G could be causing the VRM on the motherboard to crash. Does anyone have a cure for my crashing issue?
Oct 9, 2019
34
I used to get this error alot and still do if CPU usage spikes (cause of al the stuff i have running in the background. Have you overclocked recently, if so try reverting back to the original clock of the CPU. I dont know if overclocking memory can cause this as well but if you have that could be another cause. Also, if you use the IGPU for gaming, make you you allocated the 2GB memory to it in the BIOS and make sure that all drivers and software is up to date.
