My turtle beach (ear force recon) audio jack is bent. Whenever i play my headphones audio cuts out and i need to bend it in a certain way to make it work again. What do i do??
Fix the jack or replace the headset it, there are no secrets on how to fix broken equipment. Look online for a replacement part, check on how the wired are soldered on the old one and solder them up the same way on the new jack.
