How to fix chassis intrusion nothing works
Cripnicgiant
Commendable
Sep 14, 2016
I was setting up my BIOS and I saw the chassis intrusion I thought it would be something good but the I was blocked out so I took out the chassis cap and now the pic doesn't work it only turns on and has all of the fans running. I have an Asus B150M-CD3 please help! I did the bios battery thing and I put the cap back in and it still doesn't work it just sits there and none of the usbs or inputs work.
chassis intrusion is the computers side case is open, Most likely a push botton senson or a connected ground somewhere hidden to trigger it. put abck on the cap, or use something metal, I don't want to recommend anything, in urgent times, I have used tinfoil, Thats solely up to you. or you can drop some solder on it, buy a replacment cap, use some wire.
Edit:Yea nvm, im tired, didint even think he/she was messin with the bios. first thing stated l0l
