Question How to fix Corsair aio pump whine.
Jul 3, 2022
Anytime I turn the pc on the pump will whine extremely loudly until I turn the pc off and then on again. After that it's fixed.
Model for your Corsair AIO? In the past any power that's higher than 12v to the pump would cause the issue(whine)...that was 5~7 years ago. The solution, most often was to introduce a resister to make sure a constant 12v was being supplied to the pump, if more than 12v was being supplied to the pump.
Speaking of which, make and model of your PSU and it's age?
Icue H100i rgb pro xt, it is only maybe three months old.
Thank you.
