Hello fellow Windows Wizards.
(If I have chosen a wrong place to post I apologise, I'm new to this forum)
Recently I've encountered a strange error.
My PC was working just fine untill about 3h ago. But now whenever I turn it on, first I'm greeted with "Shell infrastructure host has stopped working" message,
and when I choose the "Start debugging" option I'm immediately struck by another message that reads: "Visual Studio Just-in-Time Debugger
an unhandled win32 exception occurred in sihost.exe [4340]. Just-In-Time debugging this exception failed with the following error: No installed debugger has Just-In-Time debugging enabled..."
The issue is that after I click "OK" on that window my PC is stuck in a constant Explorer shutdown loop. I cannot open my Start Menu, my toolbar is appearing for a second then it's gone. And my Background is just a black screen. I am able to open Task Manager and run new tasks though it but my focus is constantly being shifted off the window I'm trying to type in. Here is the video showing this state:
View: https://youtu.be/UfVOnTzOkiU?si=TxB2gO3zarchIMSV
How I arrived at this point:
Recently I have bought 4x8GB used Memory Ram kit from G.Skill 3200MHz CL16, over couple of recent days I was testing those ram modules because when I put them in initially my PC crashed under heavier game load. I was testing them with MemTest USB drive. The sticks were showing errors but the PC booted everytime and everything was working just fine, untill I put in my old RAM stick that I was using before. (GOODRAM 2666 CL 16 IRDM-X)
I tried:
Roughly checking all the connections on my MOBO
Refitting the RAM module
Resetting MOBO settings to optimised deafults
System file checker through CMD prompt
Renaming Explorer Key in the regedit
PC specs:
Gigabyte AB350M-DS3H V2 Motherboard
Ryzen 5 1600AF CPU
G.Skill Ripjaws 3200MHz CL16 "newly bought ram"
GOODRAM IRDM-X 2666MHz CL 16
Please help, LMK if you need to know anything more
I tried:
PC specs:
Ryzen 5 1600AF CPU
