How to fix flickering pixels on my monitor?
shui7244
My monitor has horizontal flickering pixels all over my screen. I used the same cable and hooked it up to my laptop and there was no problem. The image is smaller than the original picture.. If you look closely under AMD Catalyst Control Center, you'll see small white dots going horizontally. There are other pixels going horizontally across the screen. When I disabled or uninstalled the display adapter, the pixels disappeared.
My specs are:
Intel i5 750 2.67GHz
Windows 8.1 Pro 64-bit
G.Skills Ripjaws 4 GB RAM
Sapphire ATI Radeon HD 5770
8d7g1heyv
