how to fix half white screen on laptop
There is a remote chance that the problem could be with the internal display cable, but most likely you have a cracked/broken LCD. LCDs cannot be fixed-only replaced. This is a job for a knowledgeable technician and could cost a few hundred dollars depending on your particular model.
no there is no cracked or broken and display cable is ok
You need to replace the LCD panel. I have done plenty of them and if you get a guide it will help. Google your model and "LCD Replacement" and see if there is a manual or video on how to do it. It is delicate work but anyone can do it with patience.
If your GPU can display to an external monitor then the problem lies between the gpu and the LCD. A small crack may be invisible.
Lack of patience is precisely why most people should not even think of attempting this sort of repair :) They will cause more harm than good if they try. They could do it right, but they won't.
