[SOLVED] How to fix it?
OK...
Type in Language Settings in the search bar.
Scroll down and click on Administrative language settings under Related Settings.
Under Language for non-Unicode programs, click the Change System Locale button.
What does it say for Current System Locale? (I have English (United States) and Beta is unchecked.
-Wolf sends
Not all software uses the degree symbol (° ) since it is somewhat superfluous. Instead they show C for Celsius anf F for Fahrenheit which is more useful information.
Did you even open link with a picture? It was fine before. Only started to happen after reinstall. And I want to know where and what I did wrong
OK, so I've install HWINFO and I'm still unable to duplicate the issue. I'm still seeing the Degree Symbol °
Let's go back to the Character Map. Can you confirm that under the Arial Font, the code for the degree symbol is U+00B0?
Click on the degree sign which is located about in the middle of the first page of characters:
S
g
Is the column where you'll find it.
-Wolf sends
S
g
-Wolf sends
Yes. I even tried to reinstall HWinfo
OK...
-Wolf sends
OK...
-Wolf sends
I had Beta on. After turning it off, everything is fine now. Thanks)))))))))))))
Reactions: Wolfshadw
