Ok, this might make some of you cry. I bought the 172X and its everything the hype said it was. Mine had no dead pixels, it was perfect. Until the other day when I got a very small scratch in it. If you don't know its there you'll probably never notice. But it is especially visible when it is very white or yellow around that area. And if you know where it is you keep noticing it and it gets very annoying. Samsung wont do anything about it obviously. So how do I repair the scratch? There has to be a way to make the monitor like new again, right? I found suprisingly little material about this by searching google. I can't imagine that with all the laptops and such that nobody whoever scratched their lcd had a desire to fix it. I'm looking for maybe some sort of polish I can rub a very small amount of in the area of the scratch with a microfiber cloth, or something of that nature. Does anything exist or am i going to be dealing with this forever? I just got this monitor, so if I don't fix it then it is going to haunt me for a very long time.
"I EAT YOUR BRAIN"
-Mindflayer
CTHULHU for President in 2004!
"I EAT YOUR BRAIN"
-Mindflayer
