How to fix overheats on Samsung
Suraj_r
Commendable
Feb 20, 2016
I just bought the S6 edge... This thing overheat like crazy. If i play Mortal Kombat, it overheat. If i play another intense game it overheat. If i stay in fb or twitter for a long perior during the day without air conditioner, it get super hot in the back. How to settle this
Ways to fix Samsung Galaxy S4 overheating issue
> First you need to update all the apps by going to Google play store as corrupted applications and the apps which are not updated can create this error. So update all the apps, which show a message ready to update. Re-check the apps after updating, and if you find any apps showing as not updated even though you have updated it, delete it.
> Faulty SD-card might be a strong reason behind this problem, so format the SD-card and then insert it in your phone to find out if the problem is reduced to some extent. Take backup of all the data before formatting.
> If you are facing the overheating issue due to the software-related problem, then OTA updates can fix the Samsung Galaxy S4...
> If you are facing the overheating issue due to the software-related problem, then OTA updates can fix the Samsung Galaxy S4 overheating issue.
> Close any apps that you are not using as many apps at a time can overheat your phone. But if you don’t notice any change after closing the apps, then it might be a hardware problem, and you have to contact the service center in that situation.
> If water has been fallen on your phone recently, then it can also create this overheating issue. If this is the case, the service center is the only way to get rid of this issue.
> Disable the Bluetooth, GPS and also dim the screen.
> If the phone is getting heated while using ear piece then you need to put your phone in CPU power saving mode. For that go to Settings > My Device > enable Power saving mode. Now you need to click on the power-saving mode tab and it will open a new page. There you will see three options, among them CPU power saving tab needs to be clicked on.
> Putting your Galaxy S4 into the airplane mode could be useful if the phone is getting overheated while charging. The reason is when the phone is charging the battery is in use continuously for searching wifi signals or network and in such a situation overheating problem occurs in some phones.
So check all these steps and if the problem still exists, then contact your dealer or service provider and ask for a replacement.
Source- http://www.gogorapid.com/how-to-fix-your-phone-getting-overheat/
