how to fix ping ?
littlekevin
can someone please help me i've been having a problem with high ping in a few games mainly cs-go and would like a fix i have a power line connection which i have just recently bought but didn't seem to change anything thanks in advance
you cannot improve the server latency of your games if the source of the problem is actually the server and how your internet service provider DNS is connected with them. im sorry but the power line will not help you improve. we are at their mercy.
only things we can do is
** restart your router
** refresh your internet settings (e.g. disbable/reenable network adapter, run commandlines like "ipconfig /flushdns","ipconfig /renew" or "netsh winsock reset")
** get a less congested bandwidth. if youre wireless at 2.5Ghz go to teh 5.0Ghz connection. if youre wired or have a limited internet plan like a 30Mbps line, then make sure nobody else is download at max speed or continously using netflix for example while you are playing games.
** tweak your network adapters connections and your windows. there are alot of google sources you can find regarding on how to do them.
** wait until your game support forums will announce a fix to their servers
if you want reliable ping to their servers, you can subcribe to a service which of course you will pay. there are services called "killer ping" or "wtfast" that will provide a reliable DNS route to the game servers which may improve your game latency.
Latest posts
