[SOLVED] How to fix pink artifacts and RTX 2070 not working?
Dec 15, 2021
Suddenly my pc has shut downed and when I restarted the pc pink artifacts have appeared all over the screen.
GPU is bought on 15.11.2018. Other components bought date is 27.9.2020.
I tried updating BIOS, reinstalling GPU drivers, connecting GPU to 3 different monitors on all ports, baking GPU for 12 min in the oven at 200 degrees 3 times, and checking if there is any disconnected peace on the GPU...nothing helped. When I start BIOS settings no pink artifacts are showing and it looks normal.
Does anyone have a solution to this?
Pictures of artifacts: imgur.com/a/ucMY20y
