How to fix quantum break lag and fps drop??
Fady__gamil
165
How to fix quantum break lag and fps drop????
Will remedy release a new update that fix issues or not?????
My PC:
INTEL CORE I5 3340, 3.1GHz 6MB CACHE
GIGABYTE GEFORCE GTX 960 WINDFORCE 2X OC 2 GB
KINGSTON HYPER X FURY BLUE 8GB,1600MHz
BENQ GL2460 24 INCH MONITOR
WINDOWS 10 PRO
I was reading THIS
http://kotaku.com/massive-update-fixes-a-lot-of-quantum-breaks-pc-problem-1774009227
*Also, Microsoft keeps adding things to UWP->
https://blogs.msdn.microsoft.com/directx/2016/05/10/unlocked-frame-rate-and-more-now-enabled-for-uwp/
**If possible, you might want to try using NVidia's Adaptive "HALF" VSync option (may not work for UWP):
a) start and close game
b) NVidia CP-> Manage 3D settings-> "add game" (game should be near top)-> find the "Half" Adaptive VSync option, enable and SAVE that
c) for 60Hz monitor that will lock to 30FPS, but disable VSYNC if you can't maintain 30FPS (you get screen tear then but not VSYNC related stuttering).
Summary:
I don't have the game, and the UWP and various recent changes...
Not sure, but have you dropped the settings to the LOWEST possible, with VSYNC OFF (to avoid stutter), to see if the game runs better?
Your CPU is just below the minimum spec and your GPU just above so don't expect high settings
"The minimum specs remain the same: i5-4460 or FX-6300, 8 GB of RAM, and a 2 GB GTX 760 or R7 260x. You'll also need to be running a 64-bit version of Windows 10."
I was reading THIS
Summary:
I don't have the game, and the UWP and various recent changes make helping even harder.
Frankly, I'd consider putting the game aside for two months and play something else while they sort out some issues.
It seems to be very hungry for video and system memory.
I can get 50-60fps on medium settings 1080p but the fps sometimes drops down and even if i played on lowest settings it sometimes drops down too.but i will try what you are asking me to do(disabling vsynch)
i have the Config that you own but i only have i3 4160 @ 3.6 Ghz + 16 Go RAM 1600 Mhz Avexir Blitz Series + Gigabyte GTX 960 4Go + Win7 64 Ultimate.
= The Main issue with quantum Break is " Space Refelctions " this is the origin of fps drops and lags, just turn it " off "" and lock fps to 30 that's a lot better !!!
= Here my settings = Texture = Ultra , The Rest = Medium , Space Reflexions = Off , i get around 40 fps AVG !!!
