How to fix screen not showing after installing gpu
Santiago pabon
4
Hi so i just finished installing my graphics card but after i put all the cables on the monitor but i just show black when i turn on my pc and my pc work i can ser the light and i can hear the fans do you Guys know what to do
Try this. Install ddu and select amd. Then select clean and shutdown (for new graphics card). Take the gpu out of the pci slot and make sure it's clean. Place it back in and boot the pc. Go to amd's website and make sure you download a fresh set of the latest drivers available. Then install. Should be working now.
If you can't use onboard graphics to do those steps then try taking it out of the pci e slot and placing it back in.
