HyperPro_Andrew118 Commendable BANNED Sep 29, 2020 25 1 1,545 Oct 1, 2020 #1 My GPU is MSI gtx 730 and my monitor is LG IPS22MK400H
Solution SteveRX4 Oct 3, 2020 Then you need to change your GPU or monitor. Can you swap with someone?
SteveRX4 Notable BANNED Sep 29, 2020 1,468 136 890 Oct 1, 2020 #2 Can you use Vsync then? Upvote 0 Downvote
HyperPro_Andrew118 Commendable BANNED Sep 29, 2020 25 1 1,545 Oct 1, 2020 #3 No, I only got PhysX Upvote 0 Downvote
SteveRX4 Notable BANNED Sep 29, 2020 1,468 136 890 Oct 2, 2020 #4 Then you need to buy a Freesync GPU or a GSync monitor. Upvote 0 Downvote
HyperPro_Andrew118 Commendable BANNED Sep 29, 2020 25 1 1,545 Oct 3, 2020 #5 My monitor ajve freesync but my gpu doesnt support it Upvote 0 Downvote
SteveRX4 Notable BANNED Sep 29, 2020 1,468 136 890 Oct 3, 2020 Solution #6 Then you need to change your GPU or monitor. Can you swap with someone? Upvote 0 Downvote Solution
Jason H. Distinguished Oct 20, 2013 1,765 113 20,540 Oct 3, 2020 #7 if there was a way to do that... nvidia/amd wouldnt have spent millons of dollars advertising/providing a solution to the issue..... Upvote 0 Downvote
