UncleFelow Prominent Jul 30, 2019 37 1 535 Dec 9, 2020 #1 Update: It looks like the reason is that my drives use SMR technology. Last edited: Dec 10, 2020
Solution helpstar Dec 9, 2020 use the same speed test the reviewer used. https://ccm.net/download/download-23008-blackmagic-disk-speed-test I think it´s because he copied files from one HDD to a different HDD or the files were as big as the cache of the HDD can handle
USAFRet Titan Moderator Mar 16, 2013 178,115 21,185 184,590 Dec 9, 2020 #2 What leads you to think those values are too low? Upvote 0 Downvote
helpstar Titan Dec 25, 2012 14,532 1,005 84,840 Dec 9, 2020 Solution #3 use the same speed test the reviewer used. https://ccm.net/download/download-23008-blackmagic-disk-speed-test I think it´s because he copied files from one HDD to a different HDD or the files were as big as the cache of the HDD can handle Upvote 0 Downvote Solution
UncleFelow Prominent Jul 30, 2019 37 1 535 Dec 9, 2020 #4 Forget about it. I guess the reason is because the drives are SMR. Upvote 0 Downvote
