This tutorial will provide a solution for you how to fix sound error with USB Headphones on the HTC Vive. Check if the problem is really with the USB headphones and you are ready to start. This steps will solve the sound errors with USB headphones on the HTC Vive.
All you need to do is follow this steps:
Step 1. Check if SteamVR is sending audio to the right playback device.
■ Open SteamVR > Go to Settings > select Audio
■ In the Set Playback Device > select the USB headphones that you like.
■ Open Windows > Volume icon > Select Playback Devices > Choose the output device you like > Set as Default Device
■ Make a right click on any audio device on your choice > choose Show Disable Devices and Show Disconnected Devices.
