[SOLVED] How to fix stripped case screws?
Insane Potatoz
768
52
4,990
Hi everyone, So i bought a case for my build, the DarkFlash DLM21, and the 2 top screws for PCIe cards so mount to are completely stripped out. How do I fix this? Will I just have to put glue in there or something? I haven't found a fix anywhere else so I figured this might be the place to ask if people have some experience. Thanks!
Edit: Title is wrong, I need help in stripped screw holes... not the screws themselves.
IF you have a Lowe's or a HOME Depot, there is already a drill bit that you can get that will take those worn out screws safely. They sometimes come in a set.
The drill bit is inserted after you drill a circular shape in the screw head with a regular drill bit. Then you insert the "screw extractor" into the hold, and turn until it tightens. Sometimes you have to tap it with a hammer to get it to "Grab" onto the screw head. Then you put your drill on the bit and tighten the chuck. Apply power to the drill and the screw will be magically turning, unscrewing itself from your case.
Oh no I’m not trying to get screws out, it’s the actual hole that is stripped.
