Firstly, I should start talking about how the HDD got into this situation, as it may help in solving the issue. Also, I know I shouldn't have done this but, the damage has already been done.
It started a few weeks ago. My Windows was updating and after about 4-5 hours I was met with a black screen and nothing was happening when pressing any button and I said "screw it", so I unplugged the PC. Then upon boot, Windows was trying to revert the whole update and after about 10-20 minutes I was met with the same black screen so I unplugged it again and that was the biggest mistake. I tried installing Windows again on the same HDD but it just didn't work, because when it reached a certain point during installation, it would reboot. I got another HDD and installed windows on that.
1) I looked in "This PC", the HDD isn't there.
2) I installed AOMEI Partition Assistant and I get an error if I try to initialize the disk:
Sorry, the current operation has been canceled!
Information Code: 45
Description:Failed to initialize this disk.
What does the Information Code mean? Please refer to: https://www.diskpart.com/help/errorcode.html
3) When trying to convert the disk to GPT using AOMEI, I get this error:
Information Code: 6
Description:The partition table on the disk was failed to update as the partition table is being locked by other programs, please close other programs and retry.
Information Code: 6
I will also try to re-plug the HDD later. But for now I would need some more ideas that would potentially help fix it.
