how to format a 128gb usb flash drive
velocci
1,037
16
19,285
Hi all, I have a Corsair flash voyager GT usb 3.0 128gb flash drive. It came formatted at FAT32 (at least that's what windows 7 sees it as). When I copy a file bigger than 4gb, it says there is not enough space. I know that fat32 limits the file sizes to about 4gb. so what should I format this usb drive with? NTFS?
if you want to format it as ntfs then just attatch it to your pc and when it showed up goto my computer then right click on your usb/pendrive and click on format and select ntfs in the "FILE SYSTEM" AND PRESS START wait until done
Now your pendrive becomes NTFS type ^-^
hope it helped you
