C Citadelen Reputable Jan 19, 2015 4 0 4,510 Jan 19, 2015 #1 I recently purchased a Nepton 140XL and can't seem to fit it onto my Stacker 935, it say's it's compatible with the case but the odd design makes the screw holes not align with the case. Any help is appreciated.
C Citadelen Reputable Jan 19, 2015 4 0 4,510 Jan 19, 2015 #2 I'm not using stock paste and I'm on 14 so I can't afford to buy another, I've also had it for more than 30 days so it's no refundable. Upvote 0 Downvote
C Citadelen Reputable Jan 19, 2015 4 0 4,510 Jan 19, 2015 #3 I'd rather mount it properly as it stated it fitted with the case properly. Upvote 0 Downvote
C Citadelen Reputable Jan 19, 2015 4 0 4,510 Jan 19, 2015 #4 Iraq_ARAB_GAMING_OSAMA_Iraq : Citadelen : I'd rather mount it properly as it stated it fitted with the case properly. Then find a way to mount it. This is what I've been doing for the last 2 hours, when I couldn't find a way I turned to the forums. Upvote 0 Downvote
V Vitalijus Dobilas Reputable Apr 9, 2015 1 0 4,510 Apr 9, 2015 #5 Had the same problem when i tried this combo: fan | case | radiator | fan. Solutions: 1) Use combo: case | fan | radiator | fan 2) Drill new hole 1cm from the orginal holes and radiator should fit. Upvote 0 Downvote
