How to get audio to work .Have picture but no sound.model S-Master amplifier
Keith_2016
Sony super audio CD/DVD receiver model number HCD-FX10.have a picture,no sound from the receiver please show me how to fix it
Do you get sound when you play a DVD or CD?
If not then the problem is in the HTS and is probably not worth the cost of repair.
If you do get sound then the HTS may not be connected to the TV for audio. Connect the TV optical audio output to the optical input on the HTS using a toslink cable, Check the TV manual on how to use the optical out since it might not be active by default.
The KLH receiver has no function in your system unless you want to use the radio. You would connect the tape record out of the KLH to an unused audio input on the HTS.
MERGED QUESTION
Question from Keith_2016 : "I need help with hooking up home theater system and TV and receiver and work correctly"
I have a sharp flat screen TV a Sony super audio CD DVD home theater system and klh auto receiver. When I hook all three together I get picture but no autio to work help me hook up correctly and get all three to work together....
