I have an Asrock Deskmini with an i7-9700 that will not stay even close to 4500 MHz on a long run at full load. It drops down to 3200 mhz and lower with scaling governor set to performance and temps in the low 60's. It has base speed of 3.0 GHz and boost speed 4.7 GHz and is supposed to be capable of 4500 MHz with 8 cores. However, on a 4 minute build it drops to 3200 MHz and on a 2 hour build of Lineage OS it kills PC when almost complete. I have tried it twice and both times I seen 98% complete and don't know at what point it shut down but only partial build in out directory after powering on. I have included output from turbostat if it helps. What have I got wrong ?
turbostat version 18.07.27 - Len Brown <lenb@kernel.org>
CPUID(0): GenuineIntel 0x16 CPUID levels; 0x80000008 xlevels; family:model:stepping 0x6:9e:d (6:158:13)
CPUID(1): SSE3 MONITOR SMX EIST TM2 TSC MSR ACPI-TM HT TM
CPUID(6): APERF, TURBO, DTS, PTM, HWP, HWPnotify, HWPwindow, HWPepp, No-HWPpkg, EPB
cpu6: MSR_IA32_MISC_ENABLE: 0x00850089 (TCC EIST MWAIT PREFETCH TURBO)
CPUID(7): SGX
cpu6: MSR_IA32_FEATURE_CONTROL: 0x00020005 (Locked )
CPUID(0x15): eax_crystal: 2 ebx_tsc: 250 ecx_crystal_hz: 0
TSC: 3000 MHz (24000000 Hz * 250 / 2 / 1000000)
CPUID(0x16): base_mhz: 3000 max_mhz: 4700 bus_mhz: 100
cpu6: MSR_MISC_PWR_MGMT: 0x00401cc0 (ENable-EIST_Coordination DISable-EPB DISable-OOB)
RAPL: 4033 sec. Joule Counter Range, at 65 Watts
cpu6: MSR_PLATFORM_INFO: 0x8080838f1011e00
8 * 100.0 = 800.0 MHz max efficiency frequency
30 * 100.0 = 3000.0 MHz base frequency
cpu6: MSR_IA32_POWER_CTL: 0x001c005c (C1E auto-promotion: DISabled)
cpu6: MSR_TURBO_RATIO_LIMIT: 0x2d2d2d2d2e2e2f2f
45 * 100.0 = 4500.0 MHz max turbo 8 active cores
45 * 100.0 = 4500.0 MHz max turbo 7 active cores
45 * 100.0 = 4500.0 MHz max turbo 6 active cores
45 * 100.0 = 4500.0 MHz max turbo 5 active cores
46 * 100.0 = 4600.0 MHz max turbo 4 active cores
46 * 100.0 = 4600.0 MHz max turbo 3 active cores
47 * 100.0 = 4700.0 MHz max turbo 2 active cores
47 * 100.0 = 4700.0 MHz max turbo 1 active cores
cpu6: MSR_CONFIG_TDP_NOMINAL: 0x0000001e (base_ratio=30)
cpu6: MSR_CONFIG_TDP_LEVEL_1: 0x00000000 ()
cpu6: MSR_CONFIG_TDP_LEVEL_2: 0x00000000 ()
cpu6: MSR_CONFIG_TDP_CONTROL: 0x80000000 ( lock=1)
cpu6: MSR_TURBO_ACTIVATION_RATIO: 0x00000000 (MAX_NON_TURBO_RATIO=0 lock=0)
cpu6: MSR_PKG_CST_CONFIG_CONTROL: 0x00000000 (UNlocked, pkg-cstate-limit=0 (pc0))
cpu6: POLL: CPUIDLE CORE POLL IDLE
cpu6: C1: MWAIT 0x00
cpu6: C1E: MWAIT 0x01
cpu6: C3: MWAIT 0x10
cpu6: C6: MWAIT 0x20
cpu6: C7s: MWAIT 0x33
cpu6: C8: MWAIT 0x40
cpu6: C9: MWAIT 0x50
cpu6: C10: MWAIT 0x60
cpu6: cpufreq driver: intel_pstate
cpu6: cpufreq governor: performance
cpufreq intel_pstate no_turbo: 0
cpu6: MSR_MISC_FEATURE_CONTROL: 0x00000000 (L2-Prefetch L2-Prefetch-pair L1-Prefetch L1-IP-Prefetch)
cpu0: MSR_PM_ENABLE: 0x00000001 (HWP)
cpu0: MSR_HWP_CAPABILITIES: 0x01091e2f (high 47 guar 30 eff 9 low 1)
cpu0: MSR_HWP_REQUEST: 0x00002f2f (min 47 max 47 des 0 epp 0x0 window 0x0 pkg 0x0)
cpu0: MSR_HWP_INTERRUPT: 0x00000000 (Dis_Guaranteed_Perf_Change, Dis_Excursion_Min)
cpu0: MSR_HWP_STATUS: 0x00000004 (No-Guaranteed_Perf_Change, No-Excursion_Min)
cpu0: MSR_IA32_ENERGY_PERF_BIAS: 0x00000006 (balanced)
cpu0: MSR_RAPL_POWER_UNIT: 0x000a0e03 (0.125000 Watts, 0.000061 Joules, 0.000977 sec.)
cpu0: MSR_PKG_POWER_INFO: 0x00000208 (65 W TDP, RAPL 0 - 0 W, 0.000000 sec.)
cpu0: MSR_PKG_POWER_LIMIT: 0x42020800148208 (UNlocked)
cpu0: PKG Limit #1: ENabled (65.000000 Watts, 1.000000 sec, clamp DISabled)
cpu0: PKG Limit #2: DISabled (65.000000 Watts, 0.002441* sec, clamp DISabled)
cpu0: MSR_DRAM_POWER_LIMIT: 0x5400de00140000 (UNlocked)
cpu0: DRAM Limit: DISabled (0.000000 Watts, 1.000000 sec, clamp DISabled)
cpu0: MSR_PP0_POLICY: 0
cpu0: MSR_PP0_POWER_LIMIT: 0x00000000 (UNlocked)
cpu0: Cores Limit: DISabled (0.000000 Watts, 0.000977 sec, clamp DISabled)
cpu0: MSR_PP1_POLICY: 0
cpu0: MSR_PP1_POWER_LIMIT: 0x00000000 (UNlocked)
cpu0: GFX Limit: DISabled (0.000000 Watts, 0.000977 sec, clamp DISabled)
cpu0: MSR_IA32_TEMPERATURE_TARGET: 0x00640e00 (100 C)
cpu0: MSR_IA32_PACKAGE_THERM_STATUS: 0x88280800 (60 C)
cpu0: MSR_IA32_PACKAGE_THERM_INTERRUPT: 0x00000003 (100 C, 100 C)
cpu6: MSR_PKGC3_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu6: MSR_PKGC6_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu6: MSR_PKGC7_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu6: MSR_PKGC8_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu6: MSR_PKGC9_IRTL: 0x00000000 (NOTvalid, 0 ns)
cpu6: MSR_PKGC10_IRTL: 0x00000000 (NOTvalid, 0 ns)
20.021052 sec
Core CPU Avg_MHz Busy% Bzy_MHz TSC_MHz IRQ SMI POLL C1 C1E C3 C6 C7s C8 C9 C10 POLL% C1% C1E% C3% C6% C7s% C8% C9% C10% CPU%c1 CPU%c3 CPU%c6 CPU%c7 CoreTmp PkgTmp GFX%rc6 GFXMHz Totl%C0 Any%C0 GFX%C0 CPUGFX% Pkg%pc8 Pkg%pc9 Pk%pc10 SYS%LPI PkgWatt CorWatt GFXWatt RAMWatt PKG_% RAM_%
- - 3514 93.35 3762 3002 95733 0 14287 15744 15590 5648 11545 49 10809 48 2084 0.04 0.70 0.91 0.47 1.41 0.01 1.99 0.01 0.34 3.11 0.35 1.14 2.04 55 55 86.78 350 750.03 99.20 12.73 12.52 0.00 0.00 0.00 0.00 57.09 56.01 0.23 2.19 0.00 0.00
0 0 3486 92.59 3761 3003 14720 0 1615 1770 2294 801 1585 4 1512 2 232 0.03 0.72 1.15 0.57 1.58 0.01 2.33 0.00 0.28 3.42 0.42 1.29 2.29 55 55 86.78 350 749.75 99.16 12.73 12.51 0.00 0.00 0.00 0.00 57.09 56.01 0.23 2.19 0.00 0.00
1 1 3521 93.39 3766 3003 9567 0 1997 1914 1696 677 1566 6 1393 6 351 0.04 0.66 0.77 0.46 1.68 0.01 1.74 0.01 0.48 2.96 0.35 1.39 1.91 54
2 2 3546 94.22 3761 3003 10627 0 1392 1627 1733 597 1204 4 1313 9 271 0.03 0.55 0.88 0.34 1.13 0.00 1.76 0.01 0.32 2.85 0.24 0.89 1.79 54
3 3 3480 92.49 3759 3002 16846 0 1594 2282 2302 935 1778 13 1131 5 125 0.04 0.83 1.05 0.69 1.92 0.02 1.99 0.02 0.21 3.38 0.53 1.59 2.01 54
4 4 3516 93.42 3762 3002 9037 0 2097 1960 1911 733 1375 4 1365 6 271 0.04 0.59 0.89 0.48 1.31 0.01 2.17 0.00 0.30 3.00 0.36 1.05 2.17 54
5 5 3524 93.64 3762 3001 12923 0 1926 2194 2166 734 1385 3 1240 3 208 0.04 0.78 0.89 0.49 1.26 0.00 1.88 0.00 0.23 3.16 0.36 1.01 1.84 53
6 6 3524 93.67 3761 3001 12913 0 1609 1839 1875 663 1354 3 1337 7 284 0.03 0.65 0.84 0.47 1.23 0.00 1.84 0.00 0.46 3.01 0.35 0.97 2.00 52
7 7 3515 93.36 3765 3000 9100 0 2057 2158 1613 508 1298 12 1518 10 342 0.04 0.79 0.80 0.31 1.20 0.01 2.22 0.01 0.45 3.12 0.22 0.96 2.34 51
CPUID(7): SGX
20.021052 sec
