Question How to get more power to my GPU ?
May 18, 2021
I have two 2080 Ti GPUs. One is fine and gets the power it needs. The other floats around 5 to 15 watts.
I swapped the one out for a 3060 ti, now my original 2080 ti is doing the same thing.
Cpu, i9 9900k
32 gb ram
1000 w evga gold psu
Asus maximus 10 hero mobo
May 18, 2021
What are you doing that uses 2 gpu’s? If the game/application cannot utilities 2 gpu’s then 1 gpu will sit at idle while the other does all the work.
When I'm not gaming, I have it mining. I had them working and then I add the 2080 ti, it wouldn't mine so I thought it might have been defective, so I put my 3060 ti back and now my original 2080 ti isn't drawing power like it was.
I think its some setting or a driver issue but idk. Im not sure what to check for either in the setting or the bios
