I have an ASUS VivoPC that I purchased because it was cheap and did what I wanted it to do, which was basically play around with different types of kernels. However, after following the instructions on how to get TAILS running on a PC, it is still not working. Here is what I have done so far:
1. I did create a DVD of TAILS, and then from there installed it on to the USB. I did this from another computer as the VivoPC doesn't have a DVD slot.
2. After going into the BIOS and changing the boot order, I restarted and, low and behold, it does not work! I am at my wits end here!
What setting do I have to change in the Asus BIOS in order to get it to boot TAILS?
Thanks so much!
Thanks so much!
