A Alsharad Honorable Feb 10, 2014 16 0 10,510 Feb 11, 2014 #1 Hi! I am using the Fractal Design Define R4 case which is fully painted even the inside and my PSU (Corsair Professional 750W) is fully painted too! NO BARE METAL! How can I ground myself??
Solution ahnilated Feb 11, 2014 Alsharad : Hi! I am using the Fractal Design Define R4 case which is fully painted even the inside and my PSU (Corsair Professional 750W) is fully painted too! NO BARE METAL! How can I ground myself?? Just touch the metal on the side of the case. The paint isn't thick enough to stop 45,000 volts from jumping across to your hand.
Xiembeest Honorable Jun 24, 2013 406 0 10,960 Feb 11, 2014 #2 I've hooked my antistaic band to a plugged in, painted PSU with no issues. Upvote 0 Downvote
ahnilated Splendid Nov 9, 2006 3,647 2 23,460 Feb 11, 2014 Solution #3 Alsharad : Hi! I am using the Fractal Design Define R4 case which is fully painted even the inside and my PSU (Corsair Professional 750W) is fully painted too! NO BARE METAL! How can I ground myself?? Just touch the metal on the side of the case. The paint isn't thick enough to stop 45,000 volts from jumping across to your hand. Upvote 0 Downvote Solution
U unplanned bacon Distinguished Jan 11, 2014 1,649 1 19,815 Feb 11, 2014 #4 Touch a radiator Upvote 0 Downvote
wolverine96 Reputable Mar 26, 2014 1,237 0 5,660 Oct 13, 2014 #5 Read my tutorial: How To Ground Yourself When Building Your Computer At the bottom of the page, I explain one way to ground yourself with painted cases. Upvote 0 Downvote
