That's way too hot, well into cpu damaging heat. Official core temp (afaik) for those APU's is closer to 62°C maxed, which translates out to about 80°ish by the time you see it in software.
Thing is, it's also not easily verifyable. All those amd cpus/APU's back then had temp issues, as in nobody could reliably get a reliable temp reading since amd in their infinite wisdom did not put thermal sensors on the cores, the way Intel does. So temps are done by algorithms instead. The single most accurate software is AMD Overdrive, but it works backwards sorta, it's a thermal margin. It'll tell you how much temp you have got left to play with. So a tm of 40's is great, 30's is normal, 20's is getting close and if the margin is 10 or less, you have cooling issues. If you see 0 or negative numbers, you are into damaging heat and really have an issue.
