how to hook up desktop to wireless. and which wireless to get
Depends on what you mean by "wireless', WiFi or cell data modem using 3G or 4G? If Cell Data modem, you will be limited to what's available in your area, how to set it up, instructions will be with the device you get. If for a WiFi, just get a WiFi USB stick, and connect to your WiFi signal.
