Solution ihog Dec 24, 2013 You plug the fan controller into the power supply (molex connector), and then you plug the fans into the fan controller.
ihog Distinguished May 22, 2012 5,166 2 19,960 Dec 24, 2013 Solution #2 You plug the fan controller into the power supply (molex connector), and then you plug the fans into the fan controller. Upvote 0 Downvote Solution
B Backtothere Honorable Dec 13, 2013 305 0 10,780 Dec 24, 2013 #3 ihog : You plug the fan controller into the power supply (molex connector), and then you plug the fans into the fan controller. Great so I do understand it correctly Upvote 0 Downvote
