How to increase fan speed on gpu?
poorbugger
So I have an asus gl502vm with the new kaby lake cpu and 1060 gpu. I want to increase the fan speed or control it's speed at certain temperatures. However, the problem is that i cant do it in the msi afterburner because I cant find the fan tab in the settings therefore locking my fan speed. I'm new to laptop but is the fan speed adjustable?
in msi afterburner press the settings/properties button on the lower part, in the top search for the tab called fans
set values for low temperature and low rpm, higher temps at medium rpms and high go up to 80% more or less, don't put 100% too much noise
Hi thanks for the reply but like i said, I dont have the fan tab in the settings
I will give this a go thanks for the reply
sorry, surely i got what you wrote wrong, then the other option perhaos is the solution here
